32 pin wiring harness info needed
larry the tech
Posted: July 01, 2010 at 7:21 PM / IP Logged
i have Bought a 2005 Model Delphi Part # 28000144
GM Part # 15140912 out of a 2005 GM DTS Cadillac
Can I Wire this unit as a Custom Car Stereo Install
or does this Radio Require some kind of Feedback
from the Original Cars Computer ???
Radio has a 32 pin GM 03B Connector out the Back
Do You Have Pin Out For This 32 Pin Wiring Harness ???
Thanks Larry
Larry the tech
Platinum - Posts: 13,725
Posted: July 01, 2010 at 9:41 PM / IP Logged
I am pretty sure that you have a data controlled radio.  There is no switched 12 volt wire to tell the radio you have turned the ignition switch to the on position.  The radio gets this info digitally from the car's computer.
