whats a 250 a2 punch worth?
shawn neal
Posted: July 02, 2010 at 11:42 PM / IP Logged
let me know you guys
Platinum - Posts: 13,725
Posted: July 02, 2010 at 11:51 PM / IP Logged
is the amp rated at 125 watts per channel into a 2 ohm or a 4 ohm load?  I do not remember when they changed their rating system, I do not remember if the change was mad at the A or the (.) series amps.
shawn neal
Posted: July 03, 2010 at 12:22 AM / IP Logged
2 0hm and they were rated at 250 but they would do 5-6 hundred watts easy.
Posted: July 03, 2010 at 12:24 AM / IP Logged
The ones that did 500 to 600 watts were the ones that were rated 125 watts per channel into a 4 ohm load.
shawn neal
Posted: July 03, 2010 at 2:02 AM / IP Logged
This amp is stable at 2ohms in stereo, bridged mode is stable only at 4ohms.
Posted: July 03, 2010 at 11:18 AM / IP Logged
Rockford used to rate their amps by the power that they put out into a 4 ohm stereo load.  Now they give you the 2 ohm per channel rating.  An old Punch 200 was rated at 100 per channel into a 4 ohm load.  The new 250 is rated at 62.5 wpc into a 4 ohm stereo load.  125 wpc into a 2 ohm stereo load.
I do not remember when they changed the rating system.  To answer your question I need to know if the bottom of the amp says 125 watts per channel into a ____ ohm load?  Fill in the blank.
