autopage c3 rs730 locks
addwires
Member - Posts: 25
Posted: July 21, 2010 at 3:53 AM / IP Logged
I have a Nissan altima 03, I just installed an Autopage C3-RS730 LCD and every thing is working except the locks that when the car key is in the on position or with the engine on  the car lock the doors right a way if I unlock from the doors switch open the door and as soon I close the door automatically lock the car so I can’t leave the engine on because as soonest I close any door automatically the car locks the doors .
I try to program the option 4 but it doesn’t accept it.
This is the options that I have
1. - Ignition controlled door locks & unlocks
2. - Ignition controlled door locks only
3. - Ignition controlled door unlocks only
4. - Without ignition controlled door locks & unlocks.
If any body is familiarly with this problem please I need your help.
Thank you
wilomar
calijtee1
Copper - Posts: 121
Posted: August 31, 2010 at 11:26 AM / IP Logged
do you have it programed to double unlock/lock ??
installers do it best. we got the magic hands!
addwires
Member - Posts: 25
Posted: August 31, 2010 at 12:51 PM / IP Logged
Yes it is doble lock/ulock but I allready disconnect the alarm locks wires and even like that it locks when the key is in the ignition
wilomar
metaverse
Copper - Posts: 210
Posted: August 31, 2010 at 3:05 PM / IP Logged
Does the Altima have default lock upon door close or key in ignition ? Was it that way before you started the install is what I'm asking.. some cars have the lock door in motion option or last door closed. etc
I see you're in the Alarm "B" program part of the manual for the ignition lock..
Factory Reset the Autopage Brain (Page 23 of manual for alarm/starter reset..follow that) and Pull H4/White cable from the brain (lock/unlock/12v wire) and see if it still does it..
