got an ohm problem
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 1:02 PM / IP Logged
I have an Rockford Fosgate Punch P3SD212 Shallow-mount sub and i have an Sony xm-1s amp. I was wondering if i hooked the sub in series at 4 ohms would the rms be to low or would it be better to wire it parallel at 1 ohm and turned my gain to nothing
Platinum - Posts: 13,723
Posted: July 30, 2010 at 1:07 PM / IP Logged
Is the amp capable of driving a 1 ohm load?
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 1:10 PM / IP Logged
it doesn't  say it does it only says 4ohms 290 and 2 ohms 500 so i was wondering if i did wire to 4 ohms would it only give it 290 rms
DYohn
Moderator - Posts: 10,741
Posted: July 30, 2010 at 2:06 PM / IP Logged
That sounds like your best option.
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 2:54 PM / IP Logged
i thought so just rying to figure out if that would work or not
Posted: July 30, 2010 at 3:25 PM / IP Logged
If it were capable of a 1 ohm load, it would have been listed where you found the 4 ohm and 2 ohm rating.  Wiring it at 4 0hms is your only safe option.
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 3:31 PM / IP Logged
if i wired 2 of the amps in series and then wired 2 of the subs in series/parallel would that be an ok setup?
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 4:02 PM / IP Logged
nevermind that won't work
haemphyst
Platinum - Posts: 5,059
Posted: July 30, 2010 at 4:04 PM / IP Logged
If you want to see some of the most spectacular fireworks in your trunk imaginable, then wire two of those amps in series.
Basically what I am saying is this:
With one woofer, 4-ohms is all you got. That's a 400 watt woofer, the amplifier output at 290W (and being as it IS a Sony amp, keep in mind that is a ILS number) you'll have plenty of power. The amp will be cooler, and run with lower distortion, something that amp can use all the help it can get with. You'll NEVER hear the output difference.
:::::EDIT:::::
O... M... G...! LOL Even Sony themselves say "Make Believe"! I wonder if they are referring to the 290W RMS output of this specific amplifier! BWAHAHAHAHAH!!! On the top of the page... That, by the way is the UK home page for that amplifier. You'd never read anything like that here!
zero73188
Member - Posts: 6
Posted: July 30, 2010 at 4:23 PM / IP Logged
ok thank you guys i felt dumb after i realized what i ask with that last question
Thursday, November 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
