recommend installer in socal
tredee
Posted: August 08, 2010 at 2:28 PM / IP Logged
Can anyone recommend a good installer within SoCal? I'm not looking for any hack work or shortcuts. I've got a 92 Civic that Id like to get rewired. I want to replace power wire going to the alternator and starter, plus any grounds that are necessary. Id also like to run new speaker wire to all 4 doors back to the trunk for an amp install. I am a home a/v installer by trade so I am very meticulous. I am looking for someone who thinks along the same lines to do the work. If necessary I can provide all material as I do have access to Stinger. Thanks for the help.
icearrow6
Copper - Posts: 497
Posted: August 08, 2010 at 2:41 PM / IP Logged
will you want custom fabrication of any sort?
Are you currently having problems with your system?
tredee
Posted: August 08, 2010 at 2:46 PM / IP Logged
Nope no real custom fab. I just want to have the big 3 upgrade performed, and any other wiring replaced under the hood as necessary. I've never been a fan of using stock speaker wire so I'd also like that replaced. Its just tough to find a competent installer who will route wiring correctly and who uses bushings/drills holes in the correct locations to avoid wire chaffing. I dont have a system yet, I am just laying the groundwork for it now.
