viper 5101, 90 honda accord
cencspr
Posted: August 08, 2010 at 7:19 PM / IP Logged
Hello am installing a Viper 5101 in my 90 honda accord, I have installed different tyes of remote starts before but never a viper unit. My problem is I have all wiring connected according to the manual and diagram i have from my car. the unit just flashes the lights seven times I checked the trouble shooting guide that came with unit and I have tripple checked all the connections and same issue the BLACK/ white wire is connected to the parking brake shows ground when P brake is applied the gray wire shows open when hood is closed and ground when hood is open, the toggle switch is connected and on, now the only wires i didnt connect in the H3 harnesswerepink/ white, and pink/black and the RED / white. am I missing something any help would be greatly appriciated thank you.
Jr
dasbogie
Silver - Posts: 514
Posted: August 08, 2010 at 8:21 PM / IP Logged
You have to follow the shutdown sequence if it is a manual because it comes  from the factory setup in manual transmission mode.
you have to do the following with the car running and preferrably in neutral :
foot brake
hand brake and leave off foot brake
press remote start and remove key
open door and close door
press lock on the remote
this should shut down the vehicle and enable remote start.
if your vehicle is not a manual and is infact and auto trans then you need to change to automatic transmission mode in menu 3
Advanced
dasbogie
Silver - Posts: 514
Posted: August 08, 2010 at 8:25 PM / IP Logged
to add about the 3 wires in the heavy gauge harness you were in question about, audiovox and this site list a 2nd ignition wire as WHITE/ black.  If your vehicle does infact have it then you would throw the pink white to it and 12 volts constant to the red white and omit(tape up or yank out) the pink black
Advanced
cencspr
Posted: August 09, 2010 at 6:45 PM / IP Logged
first of all let me thank you dasbogie for helping me out ok I tried what you posted no luck once the car is running I press remote start nothing happens no led flash no light flas nothing so when i remove key car shuts off like normally. do you think I have other issues? now I did exactly the steps you posted no luck so I checked the wiring related to the shutdown mode brake wire while car running with meter i checked to see if i get voltage when i hit pedal I do battery voltage when i enguage parking brake wire gruonded and same when i open door and hood pin, am really at an impass.
Jr
cencspr
Posted: August 09, 2010 at 7:21 PM / IP Logged
ok here is how the power wires are hooked up to car just to see if am ok
pink---BLACK / YELLOW
RED / black--white
red--white
orange--yellow
purple--BLACK/ white
Jr
dasbogie
Silver - Posts: 514
Posted: August 09, 2010 at 7:35 PM / IP Logged
That looks good according to the wire diagram from bulldog.  You have not specified if this is infact manual trans or auto.  Do you have the door trigger wire hooked up, green wire from the viper?  Is the Red wire from the 12 pin harness hooked to constant juice?
Advanced
cencspr
Posted: August 10, 2010 at 11:15 AM / IP Logged
sorry about that its a manual trans, yes i have the door trigger hooked up the green wire and the red has 12 volts conected to a 12v source from fuse pannel.
Jr
