engine temperature
t&t tech
Platinum - Posts: 2,622
Posted: August 18, 2010 at 8:58 PM / IP Logged
Ok guys totally random question. What's the average temperature an engine has to be at before cooling is desired?
lspker
Silver - Posts: 503
Posted: August 18, 2010 at 10:12 PM / IP Logged
Ideally, it would never need cooling, making it more effient.
Way back in the old days, thermstats were to open around 160 f, the newer stuff around 105 c, mostly because the hotter running makes reducing pollution easier.
oldspark
Gold - Posts: 4,913
Posted: August 19, 2010 at 2:31 AM / IP Logged
Ditto...
Too cool damages the engine.
So too does too hot.
Older 1960s-1970s engines like mine are low pressure (radiators; eg, 7psi) with ~82°C thermostats.
But newer engines run coolant (hence hotter) and higher pressures, and higher thermostats.
It really depends on the engine etc.
awdeclipse
Copper - Posts: 285
Posted: August 19, 2010 at 7:31 AM / IP Logged
90-100c is "industry standard" regarding a target temperature.
Projects I have worked on will run upwards to 130c before things start shutting down. For instance, the AC will shut off around 135c and the engine will go into a form of limp-home at 140c
These numbers are referenced from some Gasoline port and direct injection projects I've worked on.
Platinum - Posts: 13,725
Posted: August 19, 2010 at 3:46 PM / IP Logged
Temperatures above 100C are very dependent on pressure in the cooling system.  Darren we really need much more info about what you are asking to be able to answer this question.
oldspark
Gold - Posts: 4,913
Posted: August 19, 2010 at 4:56 PM / IP Logged
And whilst systems may not boil until over 130°C (~270°F), that doesn't mean the engine components & systems appreciate it....
t&t tech
Posted: August 19, 2010 at 7:18 PM / IP Logged
At mr idiot, i had no specifics in mind it was just a thought, so i thought i'd ask, thanks for the responses by the way fellas! Appreciate it!
Posted: August 22, 2010 at 6:09 PM / IP Logged
In the real world, I don't think modern engines will run for too long at the 130c temps, think of the rubbish gaskets that go on most production vehicles these days.
oldspark
Gold - Posts: 4,913
Posted: August 22, 2010 at 6:28 PM / IP Logged
Correct. But they can get that hot - hence why somethings will shut down to postpone destruction.
It assumes you are desperate to get home and hence ignore all the bells and whistles.
Unlike older vehicles with the ignored single "what's that O light?"...
I'd say 110C maybe 115C is the max any engine would run at. Of course, it depends where you take that measurement.... And I'm probably thinking more of competition vehicles.
Ceramic engines without "coolant" (and conventional gaskets) may run hotter....
awdeclipse
Copper - Posts: 285
Posted: August 22, 2010 at 9:14 PM / IP Logged
Death valley and AZ on hot test we see upwards of 120c. But on the track you get coolant up to 130c along with the oil around 120c for quite some time.
And the guys that do hot fuel handling are looking at 130c coolant and 130c oil temps. But this is a forced condition highly unlikely to be encountered by a customer.
Do a search on GM camel mode if you haven't heard about this. Oldspark it is pretty much what you are talking about. Purpose is to get you home and pretty much scrap the engine in the process.
