two pair 6x9's to a 4 ch amp
mastermindz
Copper - Posts: 70
Posted: August 23, 2010 at 8:11 PM / IP Logged
How can I wire 4 pioneer 6x9's= pioneer ts-a6993r with power ratings as follows:
Peak: 920 watts per pair / 460 watts each
RMS: 160 watts per pair / 80 watts each
To a four channel 1600 watt amp? The amps ratings are:
400 watts/ channel at 2 ohm
160 watts/ channel at 4 ohm
800 watts/ channel at 4 ohm bridged
So what's the best way to wire these speakers to this amp?
Mastermindz
t&t tech
Platinum - Posts: 2,608
Posted: August 23, 2010 at 8:20 PM / IP Logged
One speaker per channel!
commit your way to jehovah and he will act in your behalf. psalms 37:5
mastermindz
Copper - Posts: 70
Posted: August 23, 2010 at 8:26 PM / IP Logged
So it'll be 160 per speaker, anyway I can get a Lil more power to them?
Mastermindz
perfectcreature
Member - Posts: 17
Posted: August 23, 2010 at 9:09 PM / IP Logged
Your going to roughly get the same results from them.
I would wire each to a channel. You will have a better sound stage....and your amp won't work as hard....
Platinum - Posts: 13,670
Posted: August 23, 2010 at 10:01 PM / IP Logged
There is no other safe alternative with the equipment you have.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
