2000 tahoe nbs 561t and 1700g
pats hoe
Posted: August 26, 2010 at 7:01 AM / IP Logged
 Ive got a 2000 nbs tahoe i installed a dei 561t with a 1700g bypass i want the doors to unlock i need to know what wires to hook up .Itll autostart fine hit brake it shuts down toggle switch works.From the 1700g i have the red+,black- the purple to purple data,blue to blue561 status.NOt hooked up on 561 is WHITE/ red  ,RED / white,  grey/black  ,WHITE/ blue  ,yellow, GREEN / WHITE  , GREEN/ black. and of course the blue and green  wires from the door unlock/lock.Also key sense wire  violet and black from 1700g should that be going to b9 light green wire at bcm.
brown wire at ignition switch nothing going to it(second accessory?)
pats hoe
Posted: August 26, 2010 at 8:41 AM / IP Logged
ok i think it goes like this GREEN/ black from 1700 to green lock of 561t and blue/black from 1700 to blue of unlock on 561. grey and black will have to go + dome light .Still would need to figure out the green and lgith blue from 1700.ill work on this atlunch and test it.Am i on the right rack.
Other thing the 1700g will unlock and lock the doors on this year tahoe right?Or wil i need something else or wirein relays?
pats hoe
Posted: August 26, 2010 at 11:05 AM / IP Logged
well nothing worked ive done searchs till my eyes burned lol.at least the autostart works just need to figure out door locks.hopefully someone here will know.i found diagrams for 2002 and newer but nothing for 2000,since its first year for nbs i guess.
Platinum - Posts: 7,828
Posted: August 26, 2010 at 4:24 PM / IP Logged
Here is a link to Bulldog Security for the wiring guide:  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp  Looks like 2000 thru 2002 are the same.
I could not find a install guide for the 1700g to be sure, but I believe it does the door locks for you.  However.....
You could wire directly from the 561t to the Tahoe.  Use the 561t's blue and green lock/unlock wires connected to relays as per this diagram https://www.the12volt.com/doorlocks/page3.asp#3wp ( the Tahoe has positive door locks ) and then to the Tahoes' wires at the BCM.
pats hoe
Posted: August 26, 2010 at 6:40 PM / IP Logged
thanks hey that will be alot easier ill wire it up tommorrow at lunch.i did notice they were positive tonight.Now the wife wants one for her 04 cadillac srx.lol thanks again
pats hoe
Posted: August 27, 2010 at 6:55 AM / IP Logged
Worked perfect did it this morning,finally have a remote to unlock doors now hated using key all the time.(remote was broke when i bought it)thanks again
Posted: August 27, 2010 at 8:03 AM / IP Logged
Great.  2000 tahoe nbs 561t and 1700g -- posted image.      Often times the old school, direct hardwired approach is the best.
Good luck with the SRX.
