adding onto existing tailgate contact
phillyfire
Posted: August 28, 2010 at 1:08 PM / IP Logged
I am trying to add another magnetic contact to a tonneau cover by splicing into a existing tailgate contact
on a DEI alarm system, I bought a no/nc contact tried both sides cant get either to work?
Posted: August 28, 2010 at 4:18 PM / IP Logged
Have you tested it first with a DMM and is one side going to ground?
phillyfire
Posted: August 29, 2010 at 12:14 PM / IP Logged
yes one side of the tailgate switch is going to ground
Posted: August 29, 2010 at 12:19 PM / IP Logged
So did you test the switch first or test it once you'd wired one side to ground and the other to the existing tailgate switch?
phillyfire
Posted: August 29, 2010 at 12:43 PM / IP Logged
go back to basics if i have one wire coming from the alarm control to the original tailgate switch,
tailgate switch has 2 wires on it one to ground, one to the wire coming from the alarm control
where do i slice into to add other contact
Posted: August 29, 2010 at 1:00 PM / IP Logged
To the alarm side of course.
Platinum - Posts: 13,726
The wire between the alarm brain and the original switch.
phillyfire
Posted: August 29, 2010 at 1:05 PM / IP Logged
i worked for a alarm company for ten years (residential / commercial) i know nothing about car alarms
so i would go from single wire coming back to one switch out to other then out of second to ground
Posted: August 29, 2010 at 1:07 PM / IP Logged
Yes. This is so basic I shouldn't need to explain all of this.
