python 991 for 2000 honda passport
Posted: September 12, 2010 at 2:07 AM / IP Logged
Find the OEM hood switch if there, it will work better than anything you can fit.
Neutral safety switch wire goes to parking brake.
If you join trunk trigger to doors, you will need to diode separate, also you won't get any warnings as to whether you've left a door or the trunk open.
Believe me when I say this is a disaster waiting to happen, seek professional help.
Some of these factors appear beyond your understanding and we can't show you through the whole installation.
sape33
Member - Posts: 31
Posted: September 15, 2010 at 7:14 PM / IP Logged
Ok Thanks for your worries about my work I apreciate that.
I understand everything you said.
I almost finish intalling my system. ts all working now. I just need to make a hole in the firewall to conect the siren (I can only hear horn now) and run a wire Amp too. Everything is working fine. Remote start, door locks. I haven't install any extra sensors yet. I'm going to move the temperature sensor, to be more acurate.
I had to program with a bitwritter because it was set up for manual transmition. I'm been taking pictures because I'm going to post it in another website and link it from here in case anybody wants to see it.
Now Im going to start to solder and put everything back together.
sape33
Member - Posts: 31
Posted: October 03, 2010 at 7:20 PM / IP Logged
Ok. I,v been working too much overtime. Not time to finish this job yet. I still can't find the oem alarm dissarm wire. In this web site it says its an yellow/blue wire in a white connector. I try them all no results. Python keeps seting off the oem alarm. thanks.
sape33
Member - Posts: 31
Posted: October 03, 2010 at 7:24 PM / IP Logged
I have something in mind. How can I make some LED amber light bar add to my alarm. arm, dissarm and setting off plus also to work when I push the emergency light on.
The bar has no control. just cigarret ligther plug. Thanks
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
