radio power wire
jgauthier
Member - Posts: 9
Posted: September 05, 2010 at 6:42 PM / IP Logged
when i turn up my stereo [Pioneer DEH P3000IB] the lights and display on the faceplate dim, would installing a larger [8ga] wire fix it?
66sportfury
Copper - Posts: 81
Posted: September 05, 2010 at 6:57 PM / IP Logged
probly do the big3 would help what audio devices are you running?
ac delco am radio and sparkomatic 40 watt sound exploder
Platinum - Posts: 13,725
Posted: September 05, 2010 at 7:23 PM / IP Logged
I am betting that you have your speakers connected to the radio.  If that is the case, upgrading the constant power wire for your deck should help with your problem.  However I do think that an 8Ga. wire will be overkill.  A 12Ga. wire ran directly to the battery and fused at 10 amps AT THE BATTERY should do the truck.  You may want to upgrade the ground as well.  12Ga. from the bolt hole on the back of the deck, to the chassis of the dash.
jgauthier
Member - Posts: 9
Posted: September 05, 2010 at 7:34 PM / IP Logged
i just said 8 because thats what i have readily available, and im just running the HU, but 6 speakers, which might be pullin more power also.
Posted: September 05, 2010 at 7:52 PM / IP Logged
f you paralleled 2 speakers to one channel of the radio, you are asking a lot out of the OEM wiring of your vehicle.
jgauthier
Member - Posts: 9
Posted: September 05, 2010 at 11:32 PM / IP Logged
they are in series
oldspark
Gold - Posts: 4,913
Posted: September 06, 2010 at 8:29 PM / IP Logged
The number of speakers won't matter.
What impedance do they present to the amp?
That determines their power consumption.
