03 jeep liberty
mxxmikexx
Silver - Posts: 796
Posted: April 17, 2003 at 5:21 PM / IP Logged
does the 03 liberty have a transponder key? the audiovox tech cd i have says it has an rf based factory security system, so im assuming as long as the customer doesnt lock the vehicle with the factory remote i shouldnt have any factory alarm bypass issues with an aftermarket remote starter, correct?. i havent seen the vehicle yet, so i figured i would post this first for some info, thanks!!!!
mxxmikexx
Silver - Posts: 796
Posted: April 17, 2003 at 5:23 PM / IP Logged
sorry, forgot to add...
is there any issues with the door locks? i have pink/violet for lock and pink/violet for unlock?? negative trigger, is that right?
any other hints, advice on this install would be appreciated!!!!
Chris Luongo
Platinum - Posts: 3,746
Posted: April 18, 2003 at 6:27 PM / IP Logged
If you have a black key, no transponder.....if you have a gray key, you DO have a transponder. You can bury a spare key into a DEI 555U....or if you don't want to give up any of your keys, get the DEI 555C.
And the locks are not negative trigger. It's a one wire system, and you use negative through a certain size resistor, depending on if you want to lock or unlock.
This sheet is for a 2002, but a 2003 is probably the same or similar:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & pink/black    |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|RED / blue            |+ |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+ |ignition harness            |
| SECOND ACCESSORY|BLACK/ white        |+ |ignition harness            |
|       POWER LOCK|pink/purple *1      |- |back of fusebox *2          |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|ORANGE / black        |   |back of fusebox *2          |
|     UNLOCK MOTOR|pink/black          |   |back of fusebox *2          |
|    DISARM DEFEAT|ORANGE / purple       |   |back of fusebox *2          |
| PARKING LIGHTS +|DO NOT USE          |   |                            |
| PARKING LIGHTS -|lt. GREEN/ orange *3 |   |headlight switch            |
|       HEADLIGHTS|same wire *3        |   |                            |
|     DOOR TRIGGER|*4                  |- |right of st column,blue plug|
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|tan/black *7        |- |conn. 1, pin 7 @ BCM *6     |
|        HOOD PIN|BROWN / tan           |- |conn. 1, pin 6 @ BCM *6     |
|TRNK/HTCH RELEASE|ORANGE / pink        |- |conn. 1, pin 17 @ BCM *6    |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. GREEN/ orange *5 |- |conn. 2, pin 9 @ BCM *6     |
|       TACHOMETER|NOT grn/or or or/grn|   |ign coil, coil pac, injector|
|      SPEED SENSE|lt GREEN/ YELLOW     |   |conn. 1, pin 20 @ BCM *6    |
|       BRAKE WIRE|WHITE/ tan           |+ |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |- |steering column             |
|           WIPERS|brn/wht(L),rd/yel(H)|+ |wiper motor                 |
| LF WINDOW UP/DN|lt blue - white     |A |center console window switch|
| RF WINDOW UP/DN|brown - pur/wht     |A |center console window switch|
| LR WINDOW UP/DN|RED / blk - blu/wht   |A |center console window switch|
| RR WINDOW UP/DN|grn/wht - gry/blk   |A |center console window switch|
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|pink               |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|ORANGE / red          |+ |radio                      |
| RADIO ILLUMINATE|orange   (dimmer)   |+ |radio                      |
|       LF SPEAKER|green - brn/red     |   |radio *8                    |
|       RF SPEAKER|purple - blu/red    |   |radio *8                    |
|       LR SPEAKER|brn/yel - brn/lt blu|   |radio *8                    |
|       RR SPEAKER|blu/wht - blu/org   |   |radio *8                    |
Notes:
Note : Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555U. *1 Lock is negative trigger thru a 1.4K ohm resistor and unlock is negative trigger thru a 426 ohm resistor. MUST use relays. *2 In the top left corner in a black plug. *3 Parking lights is negative trigger thru a 910 ohm resistor. Headlights is negative trigger thru a 349 ohm resistor. MUST use relays. *4 The driver door trigger is tan and the passenger door trigger is tan/white, use both wires and diode isolate each. *5 The factory alarm disarm is negative trigger thru a 473 ohm resistor. MUST use relay. *6 The BCM (Body Control Module) is attached to the left of the fusebox. Connector 1 is a gray 26 pin plug, and connector 2 is a gray 22 pin plug. *7 The flip up glass pin switch is yellow/white in conn. 1, pin 9 of the BCM. *8 On vehicles with the premium sound system, each speaker is individually amplified.
Saturday, January 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
