pls help( pwr door locks actuators )
tegra02
Posted: April 17, 2003 at 5:45 PM / IP Logged
sup gang.
its my first time installing my alarm on 90 integra...( carbine 3000 plus )...3 questions for you guys...
1: according to the diagram ( GREEN/ red ) is the door lock trigger, but when i check it on the fuse box i have about four of it...which one is the right one to connect to the alarm? and can i use the dome trigger ( blue/green ) instead of the door trigger.
2: as you know i dont have power door locks on my car but i bought 2 actuators to put in. can i use the reverse polarity wiring on it and on my alarm i have 3 wires coming out of the alarm ( power dor locks ) black, red and orange.....now which one is to go to the negative unlock and negative lock.......pls help on this i got stuck here....
3: can i tap the hood trigger to my car trunk trigger. you know what i mean.......
pls help on this, really appriciate it.....thank you..
anthony
draasch
Gold - Posts: 2,172
Posted: April 17, 2003 at 7:36 PM / IP Logged
dome light is the same as door trigger....
grenn/red at the pass. pin switch.
here some wiring info:
Constant 12 volts WHITE/ BLACK IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light GREEN/ RED (-) PASSENGER PIN SWITCH
Trunk Pin Switch GREEN/ BLACK (-) DRIVER KICK PANEL
Parking Lamp RED / GREEN (+) AT HEADLIGHT SWITCH
Power Lock GREEN / WHITE DRIVER KICK # 201
Power Unlock GREEN/ RED PANEL
#201- See Negative Pulse Door Lock Diagram.
check all of your wires with a meter first!
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
tegra02
Posted: April 17, 2003 at 8:58 PM / IP Logged
negative pulse door lock diagram? so i cannot use the reverse polarity, pls help....how to wire the whole process of door locks with........2 wire from the actuators.......and three 3 wire from my alarm........thank you guys.....
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
