RCA connection, deck to eq,
Dan M C
Copper - Posts: 220
Posted: June 10, 2002 at 8:47 PM / IP Logged
Hi again,i e-mailed PPI about the hook up of theyr eq model PPI-EQP to my NAKAMICHI cd-40Z cd player.Here it is,the Nak... has 3 sets of rca's labeled as this:1 RCA is labeled SW,i asumme for subwoofer,2 is labeled PRE-OUT REAR and the third is labeled AUX-IN.My eq PPI has 2 sets of inputs,one marked as MAIN and the second as AUX,so what goes where ?
Thank you once again !
Dan M C
Dan M C
Copper - Posts: 220
Posted: June 10, 2002 at 8:51 PM / IP Logged
What i meant about PPI when i e-mailed them was that theyr tech person said that i cannot utilize all the outputs,so i could only use one set of rca's,well i thought that my Nak will work perfect with the PPI eq,sorry i forgot to mention that.
Thanks.
Dan M C
Moderator - Posts: 12,488
Posted: June 10, 2002 at 9:04 PM / IP Logged
Hook up the REAR preout of the NAK to the MAIN on the PPI EQ and then with the subwoofer RCA you have the option of going straight to the sub amp with this and using the Nak to control the subwoofer or run an RCA from the PPI's sub output to the sub amp. The only thing that I'm not sure about is the AUX input for the PPI. Does it say anywhere on the back of the PPI if there is a separate subwoofer output RCA ? If it does , I would suggest using this instead of trying to use the Nak SW RCA.
What outputs does the PPI have ? You did not put this in your last post.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
