do i need a relay for 2nd door unlock?
the12voltuser
Member - Posts: 48
Posted: September 25, 2010 at 11:07 PM / IP Logged
I'm installing a Python 991 on a 2006 Toyota Corolla. Do I need to use a relay for the 2nd unlock signal or will the 200mA (-) be okay?
Posted: September 26, 2010 at 3:39 AM / IP Logged
Providing you are going to the car's negative trigger 200mA well be fine.
anewman
Copper - Posts: 52
Posted: September 26, 2010 at 3:42 PM / IP Logged
If it is a negative multiplex (resistors) on the unlock I would guess you need a relay in order to be able to give a predictable level of resistance with a resistor (at least I guess this is why Clifford recommend using relays on their systems with 2 wire central locking control.
Posted: September 26, 2010 at 5:03 PM / IP Logged
No it doesn't have multiplex locking. You've done a Polo with mux locking and very few cars have them. Your post isn't relevant.
t&t tech
Platinum - Posts: 2,608
Posted: September 26, 2010 at 7:32 PM / IP Logged
X2 with howard, it's toyota.
anewman
Copper - Posts: 52
Posted: September 26, 2010 at 9:10 PM / IP Logged
Sorry hadn't meant my post to be misleading. Focused on the relay needed aspect in general, rather than the car (with which I only have experience of a handful as a newbie). 2 posters above are definitely the ones to take note of do i need a relay for 2nd door unlock? - Last Post -- posted image. do i need a relay for 2nd door unlock? - Last Post -- posted image.
t&t tech
Posted: September 26, 2010 at 9:31 PM / IP Logged
Yes we realize you are a new man, lol, do i need a relay for 2nd door unlock? - Last Post -- posted image..
Mike M2
Platinum - Posts: 2,652
Posted: September 27, 2010 at 6:35 AM / IP Logged
Ok here's the way it really is. 2006 Corolla came two ways, with or without factory keyless entry. If it has it, the unlock pulse will unlock the drivers on the first pulse and the rest on the second(so no relay needed). If it doesn't have it, first pulse does nothing and the second pulse unlocks all doors. Use the wires from the key cylinder...
Mike M2
Tech Manager
CS Dealer Services
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
