791 bypass module
thuhamilton
Posted: November 02, 2010 at 7:11 PM / IP Logged
I am install a aftermarket remote starter on My 2000 Honda Prelude, and my question is
Do I need a 791 bypass module as "Bulldog" wiring diagram ,and if I do ,how can I install that .Thank you for your help
thuhamilton
smokeman1
Platinum - Posts: 1,589
Posted: November 02, 2010 at 7:50 PM / IP Logged
You could get a Fortin Key-Override-All. I have used then on my cars with good results and they have pretty good instructions.  www.ifar.ca is the website.   What type of remote start are you installing?
Platinum - Posts: 7,828
Posted: November 03, 2010 at 6:52 AM / IP Logged
The Bulldog 791 requires a spare key to be placed inside the unit & hidden under the dash.  There are only 3 wires to connect. The Red wire goes to +12v constant.  The Orange wire goes to chassis ground.  The Blue wire goes to the remote starter (-) Status Out or GWR wire.
The better choice is smokeman1's suggestion.  Better security and no lost key.  The DEI PKALL is the same as the Fortin KEY-OVERRIDE-ALL but easier to find and usually less expensive.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
