avital 5303
sean11901
Copper - Posts: 118
Posted: November 02, 2010 at 10:04 PM / IP Logged
i dont understand this harness?? why does it say that the wires supply negative for unlock on blue but + for green? lol how do i wire this? and do i need to relay these wires for the door lock or can i just hook them up to the - door lock and unlocl wies of the car
1 light blue (-) unlock output (+) lock
2 Empty Not used
3 green (-) lock (+) unlock output
sean11901
Copper - Posts: 118
Posted: November 03, 2010 at 4:51 AM / IP Logged
Nobody has any input on this problem I'm having? :(
Platinum - Posts: 7,828
Posted: November 03, 2010 at 5:24 AM / IP Logged
That remote starter has a Flip/Flop type output for its' lock and unlock outputs.
If your car requires (-) signals for its door lock circuits, Light Blue would be connected to Unlock and green would be for Lock.
If your car requires (+) signals for its door lock circuits then Light Blue would be connected to Lock and Green would be for Unlock.
Inline Diodes are a good idea, too.
Sorry for the tardy reply, I was sleeping.  avital 5303 -- posted image.
sean11901
Copper - Posts: 118
Posted: November 03, 2010 at 5:57 AM / IP Logged
Ofcourse a diode sounds like a good idea. What diode should I use? And I don't need to use these wires to power relays I can just connect them to the - based door lockes correct?
Thanks a bunch!
Posted: November 03, 2010 at 6:43 AM / IP Logged
The 1N4001 diode available at Radio Shack.  No relays needed for (-) door locks.  Diode band towards the remote start brain.
Thack79
Silver - Posts: 526
Posted: November 03, 2010 at 7:23 AM / IP Logged
what car?
sean11901
Copper - Posts: 118
Posted: November 03, 2010 at 11:39 AM / IP Logged
2010 hyundai sonata with (-) type b door locks
Posted: November 03, 2010 at 1:40 PM / IP Logged
Yes but use 1N4004, higher peak inverse voltage bands towards alarm, I noticed recently DEI have (belatedly) started telling people to use diodes with their flip-flop lock outputs.
sean11901
Copper - Posts: 118
Posted: November 03, 2010 at 3:11 PM / IP Logged
Ok cool thanks everyone! You would think that if they make flip flop polaritys like that they would make it programmable or even a jumper to select which polarity you are using
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
