Interior lights won't go off
96cam4ro
Posted: April 20, 2003 at 12:10 PM / IP Logged
I have checked the door jamb switch and it appears to be working fine.  The problem is, the interior lights won't go off even with the door closed.  The switch to turn the light off and on also doesn't work - the light will stay on.  The interior lights should also go off when I lock the car with my alarm or turn on the ignition switch but it doesn't.  Any ideas on why the lights continously stay on?  Thanks.
96cam4ro
Posted: April 20, 2003 at 12:23 PM / IP Logged
Does anyone know where the relay that controls the lights are? When we close the door, the lights don't instantly go off..it takes some time for it to slowly dim out. There must be something that controls this. I checked the door jamb switch and its fine.  BTW, it's a 96 Camaro.
Scott35
Silver - Posts: 258
Posted: April 20, 2003 at 5:31 PM / IP Logged
Do you have an alarm on it now, the brain may have a short in it, or if you don't the headlight switch may be bad.
Tacomacrew
draasch
Gold - Posts: 2,172
Posted: April 20, 2003 at 8:27 PM / IP Logged
do you dome light supervision?? if so D/C the alarm from the dome light and see if that will fix the problem.............
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Scott35
Silver - Posts: 258
Posted: April 20, 2003 at 8:31 PM / IP Logged
Make sure the passenger door is shut and the hatch.
Tacomacrew
GMC4x4Guy
Copper - Posts: 117
Posted: April 20, 2003 at 11:04 PM / IP Logged
If you just installed the alarm, make sure the doors are diode isolated.
"Drive it like you stole it"
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
