compustar 1wam s on 2000 durango
compucents
Member - Posts: 8
Posted: November 23, 2010 at 8:49 AM / IP Logged
I am starting a new installation of a Compustar 1WAM-S remote start on the wifes 2000 Durango.  This is a first time remote start for me but I have done various audio installs and have a degree in industrial electronics.
That being siad, I have the connections chart on the back of the CM4200-VF controller, the wiring list from the12volt wirings page and access to Mitchell OnDemand5 for further vehicle specific wiring digrams.  Will I need any other components, relays, diodes, resistors, etc. to perform this install?  From my reading I've seen some issues with the door lock cicuits but I'm not real sure if it applies to my Durango or not?  Also I;m pretty sure the 2000 Durango does not require a key code module (I have the standard black key).
Any help is greatly appreciated.
Thanks  Jeff
compucents
Member - Posts: 8
Posted: November 23, 2010 at 9:48 AM / IP Logged
Below is the wiring chart I plan to use for this install. If anyone sees a glaring problem please let me know.
 Compustar 1WAM-S                                             2000 Durango
_______________________________________________________________________
(+) - 12V Constant                                          Pink/Black or Red from Ignition SW
(+) - Power to Parking Light                           BLACK / YELLOW from Position 1 Headlight SW
(+) - 12V Constant (Starter ACC)      ????
(+) - 12V Output to Accessory                        BLACK/ White from Ignition SW
(+) - Selectable by Jumper                             BLACK/ Orange from Ignition SW (factory set for 2nd Ignition)
 (+) - 12V Output to Starter                            Yellow from Ignition SW
(+) - 12V Output to Ignition                             Dark Blue from Ignition SW
(-) - Ground                                                    Chassis Ground
(-) - 250Ma Light Output                   ????
(-) - 250Ma Starter Output                ????
(-) - 250Ma Output to Starter Kill      ????
(-) - 250Ma Status  Output                ????
(-) - 250Ma Rearm Output                 ????
(-) - 250Ma Disarm Output                              Light GREEN/ Orange from Position 10 kick panel connector
(-) - 250Ma Horn Output                                 No Connect
(-) - Emergency Brake Input              ????
(-) - Hood Pin Input                                          No Connect
(+) - Brake Input                                              WHITE/ Tan from Brake SW
(-) - Trunk Trigger Input                                   No Connect
(-) - Door Trigger Input  (Manual Trans.)         No Connect
(+) - Door Trigger Input  (Manual Trans.)        No Connect
(-) - Glow Plug Input                                         No Connect
    - Alt/Tach Sensing                                        BLACK/ Gray from Coil
(+) - No Connect
(-) - 250Ma Trunk Unlock Output                     No Connect
(-) - 250Ma 2nd Pulse Unlock Output   ????
(-) - 250Ma Unlock Output                                Pink/Purple from same connector as Lock?
(-) - 250Ma Lock Output                                   ORANGE / Purple from Position 4 from connector right of dash
(-) - No Connect                                                No Connect
There is also a Jumper (JM1)
inside that adjusts like this
Pin1 to 2 - 2nd Ignition
Pin3 to 4 - 2nd Accessory
Pin5 to 6 - 2nd Starter
Factory setting is Jumpered for 2nd Ignition
tedmond
Gold - Posts: 4,610
Posted: November 23, 2010 at 12:00 PM / IP Logged
you must connect the hood pin wire.
Ted
Compustar Expert
compucents
Member - Posts: 8
Posted: November 23, 2010 at 12:36 PM / IP Logged
Do you know what wire from the car to connect the Hood Pin signal to?  I am using this wireing chart for my intall.
https://www.the12volt.com/installbay/alarmdetail/711.html
Also does anyone have advice on the    (+)12V Constant (Starter ACC)   signal?  I've used the RED from Ignition for (+) 12V Constant, YELLOW from Ignition for (+)12V Output to Starter, DARK BLUE from Ignition for (+)12V Output to Ignition, BLACK/ WHITE from Ignition for (+)12V Output to Accessory and BLACK/ ORANGE from Ignition for (+) Selectable by Jumper (2nd Ignition).  I'm not sure whats left for (+)12V Constant (Starter ACC)?
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
