4 kicker comp 10 inch 4 ohm subwoofers
chasecorei7
Posted: November 26, 2010 at 4:45 PM / IP Logged
Ok I am new to this,
I have (4) Kicker Comp 10 inch 4ohm subwoofers and I would like to wire them down to 4ohm to a class D amp. I need to idea on much power to give them?
The RMS is 150 watts per each sub. They are the 2010 model.
Please give me feed back on what amps to use and I would like the amp to have a bass remote gain
thanks
haemphyst
Platinum - Posts: 5,059
Posted: November 27, 2010 at 2:18 PM / IP Logged
You give them 150 watts each. That's what their rating is, right?
Single voice coil woofers? Any 500W to 600W @ 4-ohm mono amplifier will do. Pick one.
Dual voice coil woofers? Any 500W to 600W @ 2-ohm mono amplifier will do. Pick one.
chasecorei7
Posted: February 02, 2011 at 6:53 PM / IP Logged
Which one of this amps would be best used in my set up
if anyone has a better amp please post!
i need it to have a wired bass remote and my budget is $150.00
Crunch P1-2000.1
Autotek AT2000.1
Autotek SM1-1000
Rockford Fosgate R500-1
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
