stereo or mono
rick_21_69
Copper - Posts: 53
Posted: April 20, 2003 at 6:37 PM / IP Logged
hi I was wondering what the difference was between wiring two subs in stereo....one per channel or having two bridged in mono?????thnx
Cletis
Copper - Posts: 59
Posted: April 20, 2003 at 6:49 PM / IP Logged
Amps put out more power when ran in mono.  Normally you can use it to get the most power out of your setup.
What kind of subs are you using (single or dual voice coil) and how many ohms are they, and what kind of amp.
rick_21_69
Copper - Posts: 53
Posted: April 20, 2003 at 6:57 PM / IP Logged
I plan on running two comp vr's (10" dual voice coil) off of a kicker kx 400.2.....do you get better sound imaging off of stereo or bridged mono?
Cletis
Copper - Posts: 59
Posted: April 20, 2003 at 7:20 PM / IP Logged
I don't think there will be a difference between the two as far as sound imaging.  I prefer running amps in mono if you can match it to the load correctly.  That way you get the most power out of your amp.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
