kenwood kvt 516 headunit and kicker cvt
acetone
Member - Posts: 31
Posted: December 06, 2010 at 7:13 PM / IP Logged
I'v got a kenwood kvt516 head unit and just got some kicker 10cvt65 2hom any way u can them to the head unit safely with no worries bc I bought an kenwood kac150d for them and they dont sound that good as a sub So was gunna use as door speakers but not sure if I can wire the subs to 4ohm and then use the postive of the right specker and then the neg for the left if that would do any damage to the headunit any helo would be great ty
Platinum - Posts: 13,725
Posted: December 06, 2010 at 9:38 PM / IP Logged
Are they single or dual voice coil?  If you are not running them as subs, you really should not wire them as you are asking.  Stereo separation will be non existant.
acetone
Member - Posts: 31
Posted: December 06, 2010 at 9:43 PM / IP Logged
Single voice coil
Posted: December 06, 2010 at 9:55 PM / IP Logged
I would not reccomend connecting a 2 ohm driver to any radio out there.  If it were a 4 ohm driver, then you could connect it as you were asking with no problems.  I know that the manufacturers say you can run their 2 ohm driver to any radio. I am not going to do it.
acetone
Member - Posts: 31
Posted: December 06, 2010 at 10:10 PM / IP Logged
But I can wire yhe cvt I have 2 of them sry for got to say that so I can wire yhem to 4 ohs
Posted: December 06, 2010 at 10:32 PM / IP Logged
You can wire them in series and wire them as you asked in your original post. But you will lose all stereo separation from that set of speakers. It may not seem important to you, but you will be surprised.
acetone
Member - Posts: 31
Posted: December 06, 2010 at 10:49 PM / IP Logged
So if I do wire them to 4ohms and from the head unit take the + right rear specker hook that too the speaker and then - left rear speaker hook and hook the to the neg on the speaker It wont damage the headunit right or shuld I just run them to say just the left or right side
