Ford Fiesta Ghia (1994) Alarm
Chris Luongo
Platinum - Posts: 3,746
Posted: June 11, 2002 at 8:06 PM / IP Logged
Hello Colin...is this the Colin I see all the time at www.carsound.com?
Anyway, the only information I have on the UK Fiesta is for 1991, and it's pretty sketchy.
If you can find the alarm's brain, unplug it and make sure everything else in the car still works.  (The alarm might also control the keyless entry.)
If you can find any tech info for your car, look for the "factory alarm disarm" wire.  It is usually tested by inserting  the key in the driver's door, and turning it to the Unlock position.  Hook up that wire to a permanent ground, and see if the rest of the car's features still work properly.
naughtydog
Copper - Posts: 90
Posted: June 12, 2002 at 2:56 PM / IP Logged
I dont remember the Fiesta's of that year having a factory fitted alarm.
What does the remote control look like??
Naughtydog
cva2000uk
Copper - Posts: 60
Posted: June 12, 2002 at 5:43 PM / IP Logged
same here..did fiestas that early have alarm systems?i think it could be wired up to the horn lol
"you wont like me, when i get angry" .
cva2000uk
Copper - Posts: 60
Posted: June 13, 2002 at 4:45 PM / IP Logged
sorry, i thought it was a 1984 model lol i suppose it would have an immobiliser and alarm of sorts. it works on the door lock like most old fords. plays up often like most too.. the best thing to do with that is throw it as far away as possible! they r the no1 cause of breakdowns on fords. its been along time scince i removed / bypassed one. although im sure the module resides in the drivers kickwell area.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
