560xv 98 mitsubishi eclipse
integraking
Member - Posts: 32
Posted: January 23, 2011 at 11:06 PM / IP Logged
i just recently purchased a 560xv from a friend and we tried installing it over the weekend on my 98 mitsubishi eclipse...but the problem we've come across is that when i remote start the car it'll run for like 20 secs or so and then shut off by itself and then the alarm will try again...it'll do this for three times and then just stop...has this happened to anybody else?...did i connect something wrong?...is the alarm messed up?....please somebody help
monty_77
Copper - Posts: 491
Posted: January 23, 2011 at 11:49 PM / IP Logged
i bet you you need to ether relearn your tach or hook it up and learn it.
its a white wire behind the instrument cluster or at the PCM (The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor)
or you can use a uncommon wire on the fuel injector or Coil
Posted: January 24, 2011 at 8:39 AM / IP Logged
X 2 with Monty_77, it's the tach that needs to be learned.
t&t tech
Platinum - Posts: 2,622
Posted: January 24, 2011 at 6:13 PM / IP Logged
X3 here, i jus had to contribute. 560xv 98 mitsubishi eclipse -- posted image.
zerepdivad
Silver - Posts: 605
Posted: January 24, 2011 at 6:18 PM / IP Logged
x4.   i just want to fit in...
A DMM is a beautiful thing.
integraking
Member - Posts: 32
Posted: January 24, 2011 at 8:22 PM / IP Logged
thanks monty your awesome man...i will try things out tomorrow but i also have one more problem tho i was wondering if you could help me with...when i try and start the car with the key it doesnt even crank...any ideas?
t&t tech
Posted: January 24, 2011 at 8:38 PM / IP Logged
Do you get the ignition to turn on?
monty_77
Copper - Posts: 491
Posted: January 24, 2011 at 8:52 PM / IP Logged
do you have the starter kill (anti-grind) hooked up.
i would try to hold the unlock button on the remote for longer than 5 seconds to see if it in a theft mode.
had this happen on a 160 rs unit when someone held the lock to long it turned the starter kill on and would not shut it off tell the person held the unlock for longer then 5 sec and the parking lights flashed and it would start by key again.
integraking
Member - Posts: 32
Posted: January 24, 2011 at 9:10 PM / IP Logged
im not too sure but what i did was cut the starter wire and put green to the key side and the purple to the motor side...is that starter kill?...couldnt i just reconnect the starter wire and tap the purple wire onto it?..
monty_77
Copper - Posts: 491
Posted: January 24, 2011 at 9:27 PM / IP Logged
that is the right way to do it the way you have it wired and that is the starter kill (anti-grind).
you can do that too by disconnecting the green and hooking the wire back together.
i would try to hold the unlock on the remote for a while and see if it will turn off the starter kill.
if you want to see if this is the case (that the start kill is active) pull all the fuses out of the Remotes starters and see if it will start. the relay should go to it off position with and start
