astra 4000rs 2w 1, 1998 s10 pickup
bob5731
Member - Posts: 23
Posted: February 07, 2011 at 11:17 PM / IP Logged
Hi
How do I install a ASTRA 4000RS-2W-1 into my 1998 S10 extended cab pickup?
Twelvoltz
Platinum - Posts: 2,384
Posted: February 08, 2011 at 6:06 PM / IP Logged
What exactly are you asking? If you need a wiring diagram take a look through the 'vehicle wiring' link at the top of this page. Do you have a bypass module or do you plan on using resistors/relays?
If you are not familiar with electronics, and specifically vehicle electronics, I would strongly recommend paying a professional to install it for you. Saving yourself a few dollars by installing it yourself could wind up costing you big money if you need to have your vehicle repaired.
bob5731
Member - Posts: 23
Posted: February 09, 2011 at 12:07 AM / IP Logged
What color Wirs to what whirs?
bob5731
Member - Posts: 23
Posted: February 11, 2011 at 10:09 PM / IP Logged
I will be using resistors/relays.
bob5731
Member - Posts: 23
Posted: February 19, 2011 at 6:58 PM / IP Logged
I have a 1998 s10 pickup what color wires to what astra 4000rs color wires?
chev104275
Gold - Posts: 1,436
Posted: February 19, 2011 at 7:15 PM / IP Logged
           #60257: 1998 CHEVROLET S-10 PICKUP EXTENDED CAB TRUCK
Security
     WIRE          COLOR          POLARITY          LOCATION
Battery          RED          (+)          IGNITION SWITCH HARNESS
Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
Starter 1          YELLOW          (+)          OR VIO IGN SWITCH HARNESS
All Door Trigger          WHITE          (-)          COURTESY LIGHT OR AT BCM TAN DR.+ ORG PA
Parking Lights          BROWN          (+)          AT LIGHT SWITCH OR LTBLU PLUG AT BCM
Convenience
Headlights-Lo          VIOLET/WHITE          (-)          VIO PLUG AT BCM
LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb          BROWN          (+)          AT REAR RIGHT PARKING LIGHT
Wipers-Lo          VIOLET          (+)          AT LIGHT SWITCH
Trnk Release          BLACK          (+)          AT SWITCH
Remote Start
Ignition 2          BROWN          (+)          IGNITION SWITCH HARNESS
Ignition 3          WHITE          (+)          OR PNK/WHT IGN HARNESS (TRANSMISSION)
Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS (HEAT/A.C.)
Anti-Theft Type          RESISTOR BASED SYS
Anti-Theft Descript          PASSLOCK II
Key Sense          LIGHT GREEN          (-)          STEERING COLUMN HARNESS
Neutral Safety          NOT GRDING
Tachometer          WHITE          (-)          AT COIL TOP OF ENG PASS SIDE
Speed Sense          GREEN / WHITE 4000          (AC)          PASS FRT QTR BLK 80 PIN CONN POS 16
Brake Lights          LIGHT BLUE          (+)          AT BRAKE SWITCH
Reverse Lights          GRAY          (+)          AT SWITCH ON TRANSMISSION
Horn          BLACK          (-)          BRN PLUG AT BCM
Modules
     WIRE          LOCATION
Module 1          TO RIGHT OF GAS PEDAL BELOW RADIO
Doorlocks/Windows
Power Unlock          WHITE          (+)          POSITIVE TRIGGER
PowerLock          LIGHT BLUE          (+)          DRIVERS KICK PANEL OR BRN PLUG AT BCM
LF Window Up          DARK BLUE
LF Window Dn          BROWN
RF Window Up          LIGHT BLUE
RF Window Dn          TAN
bob5731
Member - Posts: 23
Posted: February 19, 2011 at 7:17 PM / IP Logged
chev104275
Gold - Posts: 1,436
Posted: February 19, 2011 at 7:45 PM / IP Logged
Sorry I don't have those wire hopefully someone will. The kit didnt come with an install guide ?
bob5731
Member - Posts: 23
Posted: February 19, 2011 at 7:48 PM / IP Logged
http://www.scytek.net/manuals/astra/a4000rs.pdf
Violet - Starter Out 25 Amp. (+)
Red - +12V Battery Input #1
Red - +12V Battery Input #2
Brown - Ignition 2 Output 25 Amp. (+)
Yellow- Ignition 1 Out 25 Amp. (+)
Orange- Accessory Out 25 Amp. (+)
BROWN / White - Horn Output (-)
BLACK/ Gray - Tach Input (RPM Input)
Brown - Siren Output 3Amp (+)
Green - Negative Door Input (-)
Violet - Positive Door Input (+)
Pink -             Factory Rearm Out (-) 500ma
WHITE/ Black - Hood Pin Input (-)
Black - Sytem Ground (-)
BLACK/ White - Dome Light Out (-) 500ma
WHITE/ Violet - Factory Disarm Out (-) 500ma
Blue/Orange - Ground When Running Out(-) 500ma
Orange - Anti-Grind Out (-) 500ma
Gray - Trunk Release Out (-) 500ma
GREEN / WHITE - Brake Input (+)
White - Parking Light Out (+/-)
Red - +12V Input (+)
bob5731
Member - Posts: 23
Posted: March 23, 2011 at 1:09 AM / IP Logged
6-Wire Starter Harness
Pin 1 RED -   A: Main Power Input A (+). Connect to the battery or constant power wire at the ignition switch
with a minimum 30 Amp supply. Remove the fuse until the installation is complete and all wiring is
checked.
Pin 2 RED -   B: Main Power Input B (+). Connect to the battery or constant power wire at the ignition switch
with a minimum 30 Amp supply. Note: if connecting at the ignition switch it is highly recommended
to use separate power wires for each Red wire, each with a minimum 30A supply. Remove the fuse
until the installation is completed and all wiring is checked.
Pin 3 BROWN: Second Ignition Output (+). The Brown wire provides +12V for a second ignition wire. This
wire may instead be programmed for use as a second accessory or second starter wire.
Pin 4 ORANGE: Accessory Output (+). Connect to the accessory wire coming from the ignition switch that
supplies power to the heater/air-conditioner. Some cars may have multiple accessory wires.
Pin 5 YELLOW: Ignition Output (+). Connect to the main ignition wire that provides +12V when the ignition
is on and while cranking the starter.
Pin 6 VIOLET: Starter Output (+). Connect to the the vehicle’s starter wire.
16-Pin Main Harness
Pin 1 BROWN / WHITE: Horn Output (-) 500 mA. Connect to a relay to activate the vehicle’s horn when the
alarm is triggered.
Pin 2 BLACK/ GRAY: Tach Input. Connect to the vehicle’s tach wire or a fuel injector wire if the tachless
mode does not provide satisfactory operation.
Pin 3 BROWN: Siren Output (+) 3A. The Brown wire must connect to the siren’s red wire. The Black siren
wire must be grounded.
Pin 4 GREEN: Negative Door Input (-), Connect to the door switch circuit wire that shows ground when the
door is open.
Pin 5 VIOLET:Positive Door Input (+), Connect to the door switch circuit wire that shows +12V when the
door is open. This type of door circuit is usually found on Ford vehicles.
Pin 6 YELLOW : Factory Rearm (-), this wire will pulse negative upon remote start shut down.
Pin 7 WHITE/ BLACK: Hood Pin Input (-). Connect the to the hood pin switch. The switch must provide a
ground output when switch is opened.
Pin 8 BLACK: Ground Input (-), The Black wire must connect to a solid chassis ground. Clean away any paint
or dirt to insure the best possible ground.
Pin 9 BLACK/ WHITE: Dome Light Output (-) 500 mA. Connect to the wire that activates the vehicle’s dome
light, usually the door pin switch wire. (see Green and Violet door trigger wires). Note: Must Use
Relay.
Pin 10WHITE/ VIOLET: Factory Disarm Output (-) 500 mA. The Violet/white wire provides a ground output
on disarming and before remote starting to disarm a factory security system. Connect to the wire that
requires a ground pulse to disarm the factory security system.
Pin 11BLUE/ORANGE: Ground When Running Output (-) 500 mA. Connect to an optional factory security
bypass module if required.
Pin 12ORANGE: Armed Output (-) 500 mA. The Orange wire provides a ground output while armed to
activate a relay for starter defeat and anti-grind protection.
