hornet 570t
OmarR
Copper - Posts: 162
Posted: February 09, 2011 at 11:56 PM / IP Logged
The max runtime I this unit is 12 minutes.
Is there another remote start unit, which I can switch out to, that has a longer runtime, about 20 mins?
If another unit doesnt exist with a matching harness, I guess i will have to just upgrade it.
itsyuk
Silver - Posts: 505
Posted: February 10, 2011 at 8:14 PM / IP Logged
go to the downloads section and down the manuals for some other dei units.  maybe 552t, 551r. once you get "in the zone" of comparing different manuals, you will find a match in no time at all.
hopefully you have a copy of you manual to compare to the wires that you are actually using for your current model.
if you find a model that will plug directly in to your exsisting harnesses that has a Bitwriter input, you can have someone with a bitwriter program 1-99 minutes for ya.
if you have a manual for your unit, post some pics if the harness label pages.
if you dont have the manual and cant find a copy,  i have taken the backside of a module and inked it and pressed it onto a blamk page to use for making copy of the schematic. it takes a couple tries to get it right and works great .
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
itsyuk
Silver - Posts: 505
Posted: February 10, 2011 at 8:56 PM / IP Logged
well, i just compared your wiring to all the viper, python, boa, hornet and valet manuals on this site and nothing looked like it was gonna solve your problem.
BUT .. since you already have a remote start that works, buying one with an extended run time wouldnt be as hard to wire up as staring from scratch. after all, every wire you need is already gathered in one spot ready to be respliced into what ever new unit you settle on.
you might even be able to pop the old terminals out for some wires and plug them into the new units harness plug and save some splicing.
yuk
OmarR
Copper - Posts: 162
Posted: February 10, 2011 at 10:57 PM / IP Logged
Thanks itsyuk!
Yeah, I have been comparing different install manuals, and also came up with nothing. I was just hoping there was a newer bitwriter-compatible model out there.
I guess it's just an excuse for a 5902. :)
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
