lf q025a car alarm
prorange
Posted: February 10, 2011 at 4:06 PM / IP Logged
hi
could someone give me advise please
i have a vw golf convertible 1999
i would like to fit this alarm LF-Q025A
what is the best way to do it for the wiring on the car
on my car when you lock the door with key everything locks down when you fit the alarm you only need to connect to one wire?you don't need to go one door at a time?
also i have a micro-wave sensor how do you fit that in the car?the red light has to face inside the cabin area?
any advise would be grear before i start to cut wires
many thanks
Posted: February 10, 2011 at 5:14 PM / IP Logged
My advice from your questions would be to seek a competent installer.
The 99 Cab is a hybrid of Mk lV bodywork with Mk lll electrics, as an installer for over 30 years I wouldn't make any comments about this vehicle till I could have a look, e.g. Mk lll uses pos pulse lock/unlock triggers, Mk lV negative.
The lock control for the first is in the car, the second in the door, etc. etc.
Microwave no problem it's the preferred method for convertibles,
what the hell is a LF-Qo25A? Some Chinese POS? If so bin it.
Posted: February 10, 2011 at 5:31 PM / IP Logged
I've just looked at the specs on this alarm, bin it! The by-pass for your immobiliser (if you want it to work as an R/Start) will cost more than this POS.
No reputable installer will touch it.
prorange
Posted: February 10, 2011 at 5:32 PM / IP Logged
hi
many thanks for the reply
it was of ebay!!!!???
it is a cyclone {rubbish?}
on the doors lock when i put the key in to lock everything locks boot as well
also i can open the windows if i hold the key in the open postion also can close all windows if i hold the key in the close postion all windows shut/open{so i don't need any extra window close/open modules or door lock/unlock modules
some advise please i had a alarm on another car eveytime it rained hard the alarm would go off
are you from the uk/london area?
many thanks for your advise
prorange
Posted: February 10, 2011 at 5:35 PM / IP Logged
just got your last reply
i will send it back
any good alarm system/good price you could tell me about
many thanks again
Posted: February 11, 2011 at 12:40 AM / IP Logged
Please PM me,I'm in North London. I can give you good advice.
Posted: February 11, 2011 at 12:42 AM / IP Logged
Sorry, you were referring to total or comfort close, yes any decent alarm will do that for your car.
