silverado wiring
nawlinjoe
Member - Posts: 12
Posted: February 16, 2011 at 8:49 AM / IP Logged
I'm installing a navigation system in my 2006 chevy silver ado and need some help with the wiring . I need to locate the the following wiring from the bcm The car speed signal input,reverse signal input. Any help is greatly appreciated
nawlinjoe
Member - Posts: 12
Posted: February 16, 2011 at 4:45 PM / IP Logged
Or a diagram of the 2006 silverado bcm
would help also
Platinum - Posts: 13,726
Posted: February 16, 2011 at 10:16 PM / IP Logged
silverado wiring -- posted image. Speed Sense DARK GREEN / WHITE (AC) PCM MODULE AT LEFT FRONT SIDE OF ENGINE COMPARTMENT
silverado wiring -- posted image. Parking Lights WHITE OR GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH silverado wiring -- posted image.
silverado wiring -- posted image. Low Crr. Pk Lights GRAY/BLACK (-) AT LIGHT SWITCH OR BLACK PLUG AT BCM PIN B2
silverado wiring -- posted image. Brake Lights WHITE (+) AT BRAKE PEDAL SWITCH
silverado wiring -- posted image. Reverse Lights LIGHT GREEN (+) BCM BLACK PLUG PIN F
nawlinjoe
Member - Posts: 12
Posted: February 16, 2011 at 11:24 PM / IP Logged
Thanks for the reply.
racerjames76
Silver - Posts: 581
Posted: February 25, 2011 at 10:24 AM / IP Logged
Pretty sure i grabbed the VSS behind the cluster on my 2004 silvy I know the tach is White back there, VSS i am not sure of, but i know i saw a pin out somewhere online.
To master and control electricity is perfection. *evil laugh*
