indicator and aircon electrical faults
hayden224
Posted: February 25, 2011 at 10:47 PM / IP Logged
hi,
could anyone give me some answers i have a mitsubishi mirage 1998 model and after removing my deckhead yesterday (standard one)my indicators and aircon have ceased to work, i have checked the fuse box and all fuses are fine ????
blanx218
Silver - Posts: 654
Posted: February 25, 2011 at 10:58 PM / IP Logged
I'm guessing by deckhead you mean radio? If so, have you plugged the radio back in to see if everything works again?
Posted: February 26, 2011 at 1:24 AM / IP Logged
Oldspark has Oz friends called Deckhead.
A/C, bet you've pulled a plug somewhere, it's adjacent to the head unit position, as for indicators, completely different, unless co-incidental the only thing in common are the fuses, remember you also have fuse boxe(s) under the hood and the only REAL way to check them is to pull each fuse, one at a time and check continuity with a meter.
oldspark
Gold - Posts: 4,913
Posted: February 26, 2011 at 2:41 AM / IP Logged
Yeah - those deckheads blow my fuse too!
Posted: February 26, 2011 at 3:04 AM / IP Logged
Just checking young/Oldspark was alive and well.
Posted: February 26, 2011 at 3:05 AM / IP Logged
Also A/C relays are under the hood in a box next to the battery.
oldspark
Gold - Posts: 4,913
Posted: February 26, 2011 at 3:06 PM / IP Logged
And I suggest the usual - ROTATE all same sized fuses (even if the check ok!), and break & make all connectors, relays into sockets, etc.
The above should transfer intermittent (or blown) fuses and re-make bad connections...
t&t tech
Platinum - Posts: 2,618
Posted: February 27, 2011 at 11:07 AM / IP Logged
Did you plug back in the hazard control?
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
