Posted: March 08, 2011 at 10:45 PM / IP Logged
Posted: March 09, 2011 at 12:52 AM / IP Logged
Posted: March 10, 2011 at 2:18 AM / IP Logged
Posted: March 10, 2011 at 3:32 AM / IP Logged
Posted: March 12, 2011 at 1:37 PM / IP Logged
Posted: March 13, 2011 at 6:27 AM / IP Logged
Sunday, March 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
...where the Kathode = line-end "to alarm positive door trigger input" is to your door switch (ie Courtesy Lamps Switch, or Door Ajar Switches if appropriate)...
..and the other ends are: one to the normal car circuit, and one to #85 of the relay (#86 being to +12V).
Keep in mind current in a diode can flow from Anode to Cathode = Anode "in the direction of the arrow" and out the Cathode where the Cathode is the line end (aka brick wall end - current hits the wall if it comes in that end).
The arrow refers to the circuit symbol --->|--- ie, A-->|--K where we use K for Kathode because it's the mirror image diode symbol to above - ie, K--K--A.
Apologies - I thought I had a good door-switch and other stuff via diodes diagram in another thread, but I can't find it....
[ FYI - The above is not the reason for the K=Cathode, but it's the reason I'm giving because I find it easy to remember the "arrow" symbol, hence I can work out the direction of current flow +ve to -ve in the direction of the arrow.
The rest is easy....
Viz: the line end of the K or arrow --|<-- is the line end of the actual diode.
And if the line-end is is the K end, the other end must be the Anode.
And since it is +ve to -ve thru the arrow - ie, +ve into Anode & -ve at the K/Cathode, I sound as if I know something despite the fact that I never really remember whether anodes are +ve or -ve.
That's what I call "from first principles" (which is how people like me with limited memory work or survive!). ]
