viper 5901, xk 01 bypass in 08 trailblazer
dizzog
Posted: March 24, 2011 at 12:29 PM / IP Logged
Hi all,
I'll forewarn you that I'm a newb when it comes to wiring up alarms.
I've been racking my brain searching all over the internet trying to get a straight answer on this one question. I haven't been able to find anything and I'm hoping the smart people here can give me a quick answer. The question is:
The XK-01 bypass module does not control the rear doors through D2D. I believe it neither triggers the alarm nor locks/unlocks the doors. How do I wire both the alarm monitor and the door locks properly?  Which specific wires come out of the Viper/XK and where and how do these wires terminate at the BCM or doors?
Also, I've read conflicting information about the rear hatch. Is this controlled through D2D or not?
Thanks in advance!
blanx218
Silver - Posts: 654
Posted: March 24, 2011 at 9:47 PM / IP Logged
I've never had a problem with the locks with an XK01, but for door triggers you'll need to grab the rear doors under the back drivers side seat at the BCM and diode isolate them and the output from the XK01.
bndawgs
Member - Posts: 30
Posted: March 25, 2011 at 9:27 AM / IP Logged
this is what i did with my xk01 and 2004 tahoe.  Found the rear doors at the bcm and diode isolated them.  I just hooked them up along with the xk01 wire to the door trigger of my 5701.
<--------   Stayed at a Holiday Inn express last night
