dome light with prostart problem
anotherwc
Member - Posts: 10
Posted: March 26, 2011 at 7:18 AM / IP Logged
07 Honda Fit GD. (AT)
installed prostart ct 3200..everything works fine..
cept that i need a bypass..for now i just tape the chip around the key ring.......
problem is that
when i remote start my car, my factory remote "lock and unlock" dont work +
only works when i use the prostart remote to unlock it , it works, and the dome lights dont come on when i unlock it,
is there a wire i need to tap? inorder for the lights to work with the prostart remote??
cuz i'll only know if my car is unlock if i see my var light up from far...
m i missing a wire or sth??
tedmond
Gold - Posts: 4,610
Posted: March 26, 2011 at 9:39 AM / IP Logged
buy yourself a bypass and do it properly.
the pkall or fortin honda-sl3 is the cheapest bypass solutions available. Idatalink has good ones too but cost a tad more.
under remote start, the keyless entry system (honda) will no longer work, this is normal. As far as the dome light, you will need to use the courtesy lightutput from the prostart (dome light supervision)  and connect that to the domelight wire in the car. use a relay.
however, i never had an issue with domelights going on when unlocking for the japanese cars.
Ted
Compustar Expert
anotherwc
Member - Posts: 10
Posted: March 27, 2011 at 3:00 AM / IP Logged
oh ok..
thanks...cuz im in china right now...
so i cant really find bypass kits...well atleast i duno where to search...
thanks
i'll rewire them later
Posted: March 31, 2011 at 11:49 AM / IP Logged
And you shouldn't even need domelight supervision on a late Honda, the courtesy light feed is built into the lock mech.
Throw away the Honda remote fob you won't need it so that's one problem solved, as for not seeing it, have you not wired to the lights?
anotherwc
Member - Posts: 10
Posted: April 02, 2011 at 9:28 AM / IP Logged
its like this.,
when car is off.....
remote unlock - lights come on ...normal.
remote start then press unlock- lights dont come on...
i want my lights to come on even when the car is on remote start.
Posted: April 02, 2011 at 10:30 AM / IP Logged
Then use your R/S status output, link it to your door trigger. That will bring on the dome light during R/S.
