rca problems?
felty04
Member - Posts: 7
Posted: April 19, 2011 at 4:04 PM / IP Logged
all wiring was bought brand new so im hoping it doesnt have corosion ne where.
Platinum - Posts: 13,726
Posted: April 19, 2011 at 6:43 PM / IP Logged
blanx218 wrote:
Have you tested the power wire for 12V at all.
felty04
Member - Posts: 7
Posted: April 20, 2011 at 6:17 PM / IP Logged
ok so.. i tested all the wires for 12v all of them get power...still no sound out of subs. im guessing 3 subs i have r dead but i have no clue how thats possible
blanx218
Silver - Posts: 654
Posted: April 20, 2011 at 6:22 PM / IP Logged
Does the power light come on on the amp at all? Have you checked the remote turn on?
soundnsecurity
Gold - Posts: 2,720
Posted: April 20, 2011 at 6:33 PM / IP Logged
on eclipse radios the subwoofer output is called "non-fader" output, is this what you have them hooked to? also, make sure you have the rcas plugged into the INPUT of the amp and not the OUTPUT. im not asking because i think you are dumb, its just that ive seen this happen more than once. also you could buy a line output converter which taps onto the rear speaker wires and converts them into rcas. if you do this and still get no sound then you may have a bad amp. also make sure your amp is not set on HPF in the crossover section. it should be set to LPF.
