2011 nissan versa 1.6
speeddemongto
Member - Posts: 7
Posted: April 18, 2011 at 12:46 AM / IP Logged
Hello
I have just purchased a 2011 Nissan Versa 1.6. From my research it appears all the versa have the door actuators built in front the factory,so I have purchased a Viper 211HV keyless entry to install.Got all the basic functions besides the horn working correctly,but all the simple online instructions for the OEM door actuators seem to all be different. My drivers side door has a 6 Pin connector on the actuator,I will attach a pic here
2011 nissan versa 1.6 -- posted image.
From what I understand the 211hv has built in relays so I should be all set besides adding a relay in for the progressive unlock.....just cant figure out why I can get the drivers door to fire by itself first...any help appreciated
speeddemongto
Member - Posts: 7
Posted: April 19, 2011 at 12:43 PM / IP Logged
anybody thoughts/ideas?
Posted: April 21, 2011 at 2:33 AM / IP Logged
Grey lock, grey to purple unlock, NEG. pulse driver kick panel.
t&t tech
Platinum - Posts: 2,622
Posted: April 22, 2011 at 7:11 PM / IP Logged
Easy as pie.
speeddemongto
Member - Posts: 7
Posted: April 25, 2011 at 1:18 AM / IP Logged
I have no wiring for my door locks,my car is the stripped base 1.6. The relays are part of the door lock so they are installed.
Posted: April 25, 2011 at 2:13 AM / IP Logged
Er, let's get this right...
Factory relays and actuators but no wiring?
Look again.
Posted: April 25, 2011 at 2:28 AM / IP Logged
Get the looms from a dealer, that would be your first port of call.
speeddemongto
Member - Posts: 7
Posted: April 25, 2011 at 10:40 PM / IP Logged
howie,look at the picture. the actuator is part of the door lock assembly so nissan is not going to redesign that for one model lineup,they just ditched the harnesses. I guess the only thing I can do is go to a junk yard and get the wiring harness to plug into the connection
speeddemongto
Member - Posts: 7
Posted: April 25, 2011 at 10:42 PM / IP Logged
source of info
http://forums.nicoclub.com/adding-door-lock-actuators-to-base-model-t441153.html
t&t tech
Posted: April 27, 2011 at 5:50 AM / IP Logged
Oh i now catch on to what you were saying, sorry my bad, i'm kinda slow that way, well there are two ways you could possibly do this, i'll give you one, take your dmm out and set to continuity, between two of those pins and one common pin you should have continuity when the lock is locked and the other when unlocked, when you eliminate this there chould be three pins remaining, take a power fused at five amps and a ground and alternate it between the remaining terminals and you should be able to find the ones that make the actuator move, this is only if you can't get the original wiring harnesses.
