hazard on with door open
mujahid
Member - Posts: 11
Posted: July 17, 2011 at 8:30 AM / IP Logged
can anyone help me. i would like to wire my hazard lights to come on when i open my door. Is this possible or do i need a module or something.
@0 Hertz Xpertz/Team SPL
Platinum - Posts: 13,725
Posted: July 17, 2011 at 9:57 AM / IP Logged
No module needed, but it would help us if we knew what kind of vehicle you have. Are you able to remove the hazard switch to help figure out which wire you will need to power?
Posted: July 18, 2011 at 9:22 AM / IP Logged
There is more info needed. Before I can see if I can explain the process, I really need to know if you are going to be able to get to the wires of the hazard switch.
What would the Nissan B13 be called Stateside?
Posted: July 18, 2011 at 12:13 PM / IP Logged
Remove the hazard switch and find the wire that goes to +12v when the hazard switch is powered up.
Wire a relay as follows,
Constant 12V to terminal 30 and terminal 86.
The wire you found at the hazard switch to terminal 87
The car's door trigger wire to terminal 85.
I will try to find the door trigger info for you. If anybody wants to help, it is the equivalent of a 1994 Sentra.
mujahid
Member - Posts: 11
Posted: July 18, 2011 at 1:51 PM / IP Logged
thanks man and you call yourself an idiot. thanks alot
t&t tech
Platinum - Posts: 2,622
Posted: July 19, 2011 at 6:18 PM / IP Logged
door trigger is RED / white in the driver floor panel.
Posted: July 19, 2011 at 8:25 PM / IP Logged
Thanks "D"
tommy...
Gold - Posts: 1,901
Posted: July 22, 2011 at 4:57 PM / IP Logged
We ALL call him an Idiot...
M.E.C.P & First-Class
t&t tech
Posted: July 24, 2011 at 10:39 AM / IP Logged
Thanks "D"
No probs "C" hazard on with door open -- posted image.
Posted: July 24, 2011 at 11:08 AM / IP Logged
SHhhhh!!!
