viper 5901 in a supra
ask92
Member - Posts: 34
Posted: August 08, 2011 at 10:20 PM / IP Logged
I am installing a viper 5901 remote start into my 1989 turbo targa supra with a manual tranny. I need some help figuring out where some of the wires connect.
These are the wires i am unsure of how to connect:
-WHITE/ Brown Flex parking light relay 87A
-Violet starter output (car side of starter wire)..[I'm guessing this is the wire between the starter and fuse box?]
-WHITE/ Blue remote start activation (-) input
-Light GREEN/ Black OEM disarm (-) 200mA output
-Light GREEN/ White OEM arm (-) 200mA output
-Orange ground-when-armed (-) 500mA output (just go to ground?)
Diagram:
viper 5901 in a supra -- posted image.
Any help is appreciated and yes i have seen the supra wiring info on this site, and all this info is not on it. Thank you for your help.
-Andrew
Posted: August 09, 2011 at 12:36 AM / IP Logged
Having seen your comments, I'd strongly advise you not to proceed on your own. Or at least read the instructions again. Having said that:-
Cut the wire which goes to live on cranking at the ignition switch loom.
Key side to H/3 5 GREEN.
Starter side to H/3 4 VIOLET.
Ignore the rest as in don't connect and read the instructions again.
ask92
Member - Posts: 34
Posted: August 09, 2011 at 1:11 AM / IP Logged
What instructions? The only thing provided was eh wiring diagram. I am very very car savy, i just installed the supras engine myself. Its just the wording in the diagram i am unsure about.
Posted: August 09, 2011 at 3:23 AM / IP Logged
I don't think so, stop guessing and get out a DMM and test your car's wiring. Locks will be in the driver's kick panel, tach behind the instrument panel or the coil (terminal 15 or -) if there's a single coil. Door trigger will be at the driver's kick panel, probably RED / white with silver dots, indicators or lights at the ignition switch loom along with ign, ACC and possibly second starter wire TEST. BLACK/ white wire from Viper to parking brake switch. There that's all from memory and I haven't worked on one for about 20 years. That's savvy.
smokeman1
Platinum - Posts: 1,589
Posted: August 09, 2011 at 6:19 AM / IP Logged
Go to the downloads section of this site and download the install manual for the Viper 5701. It will explain each wires use. It may not have a 18 pin connector (H2 Harness), but you should be able to match up the three harness from the 5701 that make up the newer 18 pin.
ask92
Member - Posts: 34
Posted: August 09, 2011 at 8:17 PM / IP Logged
All the tings you just mentioned i already i have done. And non of them were on my list. I only need help on the wires listed in my previous post.
t&t tech
Platinum - Posts: 2,622
Posted: August 09, 2011 at 8:38 PM / IP Logged
The only wire you're using from the ones you listed would be the violet wire, you need to cut the true starter wire and connect the heavy green to the side from the key and the violet to the other side.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
