Posted: August 25, 2011 at 3:15 PM / IP Logged
Posted: August 25, 2011 at 4:29 PM / IP Logged
Posted: August 25, 2011 at 4:43 PM / IP Logged
Posted: August 25, 2011 at 7:34 PM / IP Logged
Posted: August 26, 2011 at 11:20 AM / IP Logged
Posted: September 24, 2011 at 1:14 PM / IP Logged
Posted: September 25, 2011 at 5:44 AM / IP Logged
Posted: September 25, 2011 at 10:16 AM / IP Logged
Posted: October 09, 2011 at 3:25 PM / IP Logged
Posted: October 09, 2011 at 4:32 PM / IP Logged
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
International convention calls for 85 = neg of coil and 86 = pos!
In practice this doesn't matter except that many relays have inbuilt diodes and car manufacturers will wire the relays that way.
Also my diodes are correct, you're sending neg towards the relay, the diodes are there to prevent feedback especially to the alarm and the bands are correct, trust me....remember I do this for a living!
Your last diagram, to make it work with the alarm, put the momentary switch to 85 and ground (0v) the other side of the switch NOT 12v+.
Between the switch and the alarm join the black white from the alarm, not forgetting those diodes.
Run your 12v+ to 30 and 86. Incidentally in a 4 terminal switching relay like you show 30 and 87 ARE interchangeable.
