comfort closure on jeepgch with xk01
alchi7
Posted: September 07, 2011 at 12:41 AM / IP Logged
Will the window&sunroof rollup function XK01 work in my Jeep Grand Cherokee 1999 Limited if it doesn't have "Comfort" option which rolls up windows with original keyless remote or key?
Here my car is listed as supported, but I have doubts after reading this topic. It says that XK01 simply holds the "lock" for 20 seconds.
Posted: September 08, 2011 at 7:05 AM / IP Logged
No.
alchi7
Posted: September 08, 2011 at 7:48 AM / IP Logged
That's DEI support reply:
Only windows
Sent: Wednesday, September 07, 2011 12:37 AM
To: Canada Tech Support Mailbox
Subject: Re: ClickAndChat.com On SERVER3 Visitor Has Left A Message
And sunroof will closed too?
2011/9/6 Canada Tech Support Mailbox <CanadaTechSupportMailbox@directed.com>
Pressing the lock button twice will roll-up the windows
Sent: Tuesday, September 06, 2011 8:21 AM
And how it works? I don't see on the diagram "Color: (-) Window Roll up Input" wire or something like this. Or windows will automatically roll up with "2: Green: (-) Lock Input" ?
With the XK01 yes no problem
Sent: Monday, September 05, 2011 6:03 AM
Will the window rollup function work in my Jeep Grand Cherokee 1999 Limited if it doesn't have "Comfort" option which rolls up windows with original keyless remote or key?
I am really don't understand...
Posted: September 08, 2011 at 8:49 AM / IP Logged
OK the answer is still no unless you hold your key over in the lock and see if the windows roof raise. You could always program the alarm for comfort close and see if that does it.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 08, 2011 at 10:04 AM / IP Logged
I did once use an XK01 in a 1999-2004 style Grand Cherokee and I hooked up the window rollup feature as a surprise for the customer.
I don't remember exactly what year the car was, but 1999-2004 should all be the same.
Here is what you need to know:
1. Be sure to program the feature to "on" in the XK01's settings menu.
2. It only rolls up the two front windows. Does not do rear windows. I don't know about the sunroof; can't remember.
3. You didn't mention what remote starter you're using, but you probably want to avoid using the D2D cable. You can try, but I'm not sure if it will work. The entire remote-start industry has still failed to get data-to-data to work reliably.
4. You need a remote starter that will send out a "lock" pulse multiple times. For example, the Avital 4103 will only lock the doors one time and that's it.
Make sure your remote starter is capable of locking the doors over and over again, every time you press the Lock button on the remote.
Alternately, you should probably be able to connect the remote starter's "lock" AND "trunk release" outputs BOTH to the XK01's green lock wire.............in that case you would first lock the door with the remote, then hit the trunk release button to close the windows.
5. I never tested if the window rollup works with the car running. If the remote starter is turned on, you may have to turn it off before the window rollup feature will work.
alchi7
Posted: September 09, 2011 at 5:49 AM / IP Logged
Thank you for your responses.
It seems that just have to try. I ordered the XK01 and when it is delivered, I'll try.
Chris Luongo
3. This starter is made ​​in Russia, I think its name did not mean for you.(Pandora DXL 3500) But it's no problem to send "lock" pulse twice.
alchi7
Posted: September 22, 2011 at 1:22 AM / IP Logged
I received the XK01, but it is not AMDL XK01! It is GMDL6X XK01!
This is not working with Chrysler car's. comfort closure on jeepgch with xk01 -- posted image.
And I nave not XKLoader to reflash it.
Maybe I can do XKLoader by myself? Somebody have the circuits of this?
