Testing tach wire???
emorse2323
Copper - Posts: 106
Posted: April 28, 2003 at 12:10 PM / IP Logged
What should the tach wire test theres four of the same color so when I go to test it how should the right one read?
thanks
Derek
Copper - Posts: 83
Posted: April 28, 2003 at 4:32 PM / IP Logged
What type of Vehicle?
jrilla
Gold - Posts: 1,498
Posted: April 28, 2003 at 7:19 PM / IP Logged
Between 1 and 6 volts AC and increase when the gas is pressed. Yes I mean AC, not DC.
J Rilla
Owner/Installer
emorse2323
Copper - Posts: 106
Posted: April 28, 2003 at 7:23 PM / IP Logged
its on a 2002 chevy 1500 suppose to be a white wire and theres about 4 of them.
Moderator - Posts: 12,488
Posted: April 28, 2003 at 11:20 PM / IP Logged
 Look for the wire at the ECM which is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled 'red', and VSS wire is at pin 3 in the connector labeled 'black'. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the 'red' connector, and VSS wire is located in pin 50 of the 'red' connector.
elrayodesinaloa
Copper - Posts: 120
Posted: April 29, 2003 at 6:29 PM / IP Logged
easiest way is by using an ANALOG vm and test the wire at the coil, or a non-common wire at the injectors.  accelerate and you will see the needle moving showing you difference in AC voltage. Will look like your RPM meter inside your vehicle, goes up as you accelerate ,and go down as you de-accelerate. piece of cake
dfiddy
Copper - Posts: 162
Posted: April 29, 2003 at 7:42 PM / IP Logged
I've used injector wires on most of those new chevy's....is this wrong? I've heard that some brands recognize injector wires better than a coil wire and vice versa, who's right?!
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
