2006 avalanche
Welcome Guest :)
snoboa13
Member -
Posted: September 15, 2011 at 9:43 AM / IP Logged
I need the stereo wiring and remote start wiring for a 2006 Avalanche can anyone help?
clarence1996
Member -
Posted: September 15, 2011 at 10:09 AM / IP Logged
Battery |
ORANGE |
RADIO HARNESS |
Accesory |
Ground |
BLACK/ WHITE |
RADIO HARNESS |
Illumination |
BROWN |
RADIO HARNESS |
Dimmer |
GRAY |
RADIO HARNESS |
Power Antenna |
DARK GREEN |
RADIO HARNESS |
LF Speaker (+) |
TAN |
LF Speaker (-) |
DARK GREEN |
RF Speaker (+) |
LIGHT GREEN |
RF Speaker (-) |
ORANGE / BLACK |
LR Speaker (+) |
BROWN |
LR Speaker (-) |
DARK GREEN / WHITE |
RR Speaker (+) |
DARK BLUE |
RR Speaker (-) |
BLACK |
Amp Location |
UNDER CENTER CONSOLE |
Steering Cntrls |
YES |
Speed Cntrl |
YES |
Radio Security |
YES |
12volts red (40A), red (40A) + ignition harness Starter yellow + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition white + ignition harness Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system. Third Ignition N/A Accessory orange + ignition harness Second Accessory brown + ignition harness Keysense lt. green - ignition harness Power Lock use 457G or 456G module Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601. Power Unlock see power lock Lock Motor gray 5wi driver door module in door Unlock Motor tan 5wi driver door module in door Parking Lights+ brown + driver kick panel Parking Lights- gray/black - switch or BCM, brown plug, pin B2 Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Hazards white - hazard switch Turn Signal(L) dk. green + turn signal switch Turn Signal(R) lt. green + turn signal switch Reverse Light lt. green + BCM, black plug, pin F Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Door Trigger see notes - see notes Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each. The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Dome Supervision gray/black + BCM, black plug, pin E Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Trunk/Hatch Pin N/A Hood Pin N/A Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm lt. green - driver door module in door Disarm No Unlock see factory alarm disarm Tachometer white ac instrument cluster, pin A5 or PCM Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10. For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown. Wait to start N/A Brake Wire white + brake pedal switch Parking Brake lt. blue - switch or BCM, lt. blu plug, pin A7 Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Horn Trigger BLACK / YELLOW to black - switch or BCM, gray plug, pin B9 Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. Memory Seat 1 red + driver door module in door Memory Seat 2 pink + driver door module in door Memory Seat 3 N/A + Interface Module: Category: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T Notes: The Passlock 2 wire colors are yellow, black, and RED / white (not used). TheWire1
Platinum -
Posted: September 15, 2011 at 5:24 PM / IP Logged
Are you replacing your radio? If so, I highly recommend purchasing the appropriate wiring harness so you do not have to cut the plug off of your wiring.
Wednesday, May 8, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
