Why does a mono Amp with 4 outputs??
carguy411
Silver - Posts: 683
Posted: April 29, 2003 at 6:56 AM / IP Logged
i have a us acoustics mono block amp and it stable to 2 ohmsbut i dont understand why there are still 4 speaker outs on it, i see alot of mono amps like that?is it forwireing flexiblility or something?any help would be great
\thanks
x6369x
Copper - Posts: 108
Posted: April 29, 2003 at 4:17 PM / IP Logged
It's for ease of installation. For example, if you were running 2 subs, and using 2 sets of 8 gauge speaker wire. The second set of terminals would allow you to wire both subs directly to the amp, without having to use some type of barrier strip to split the wires.
Friends Don't Let Friends Bump Stock.
Big Purds
Silver - Posts: 574
Posted: April 29, 2003 at 5:51 PM / IP Logged
some companies do this because it does make life easier in some circumstances...just adds flexibility to your system...
carguy411
Silver - Posts: 683
Posted: April 30, 2003 at 7:26 AM / IP Logged
does it help in the wiring of the ohm load
right now i have 2"10 dual4ohm subs wired to 4 ohms becasue my amp ant handle a 1ohm load but can handle 2 ohms is it possible to wire each soeaker to its own output so it gets each gets a 2 ohm load
i dont think it would work but just makin sure
