02 grand caravan
mobileedgeny
Member - Posts: 32
Posted: November 25, 2011 at 3:23 PM / IP Logged
on a 2002 dodge grand caravan es with alarm where does everybody get 12v power for remote start? It shows a 10 amp gin wire. do people use that with a 10 amp fuse in the remote starter or go to the battery? Using compustar with the blade AL for sliding doors and everything.
dasbogie
Silver - Posts: 514
Posted: November 25, 2011 at 10:25 PM / IP Logged
battery
Advanced
Chris Luongo
Platinum - Posts: 3,746
Posted: November 26, 2011 at 5:07 PM / IP Logged
I always go to the column, and I get rid of the two 30-amp fuses that come with the unit and put everything on a single 7.5-amp fuse.
You definitely want your fuse to be smaller than the OEM fuse under the hood.
That way, if your wiring job fails and shorts to ground, only your aftermarket fuse will blow, but the OEM fuse will remain good, allowing the car to be driven.
If you're still worried about grabbing power at the ignition switch, there are some thick constant wires in the kick panel, and possibly at the BCM too. Much neater and easier than going out to the battery.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
