multiple flashing alarm led's via relay?
LooneyG
Member - Posts: 43
Posted: November 28, 2011 at 2:59 PM / IP Logged
I did do some searching around the Site and was unable to find this Info but is there a way to add multiple 12V LED's to a Car Alarm's LED port via a Relay and have them all Blinking ? If so could somebody maybe post a Diagram and if there is any other way to make this happen please post it too.
KPierson
Platinum - Posts: 3,527
Posted: November 28, 2011 at 5:19 PM / IP Logged
You would need a transistor as a relay would draw too much current. You should be able to find schematics on the internet for this.
Kevin Pierson
Platinum - Posts: 13,670
Posted: November 28, 2011 at 7:20 PM / IP Logged
Radio Shack sells a 12volt flashing LED.  You should be able to connect them to a 12 volt constant source, and ground them to your alarm's Ground when armed wire.  It is the same wire to which the starter kill relay is connected.
birdman41
Member - Posts: 16
Posted: December 08, 2011 at 3:31 AM / IP Logged
If memory serves me correct you can connect up to 2 leds to one port..just wiring them in series with one another.
Posted: December 08, 2011 at 5:19 AM / IP Logged
Actually, it's up to 3 blue and 5 red when wired in series.
This ONLY relates to DEI group product with 2.5 volt LED.
From 12V+ they will need a resistor of more than 800 ohms in series.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
