viper 5501 cold weather issues
bigudi27
Posted: December 08, 2011 at 11:15 AM / IP Logged
There is installed a Viper 5501 and Idatalink bypass in my 2007 Mazda 5. In the morning when the car is cold I start it up, it runs for 3 seconds and shutt off, it tries cuple times to start up until finished the cycle,(it takes about one minute). In other hand when the engine was running and it is hot the Viper remote starter works fine but the doors keep unlocked. I need some advise because the cold is here and I really need the remote starting working.
Thanks a lot.
Bigudi
chev104275
Gold - Posts: 1,436
Posted: December 08, 2011 at 11:39 AM / IP Logged
Try relearning the tach signal to a higher rpm. Cold engine starts the RPMs are higher therefore the remote start thinks its over revving and shutting down
bigudi27
Posted: December 08, 2011 at 12:33 PM / IP Logged
Thanks chev104275, could you please, let me know what steps do I have to follow to relearn the tach?
Thanks,
Bigudi
chev104275
Gold - Posts: 1,436
Posted: December 08, 2011 at 12:52 PM / IP Logged
I don't have the install guide with me but check the download section on this site it should be there.if not I have in my tool box at my house I could get it later. I believe its start the car with the key and hold the programming button till the led lights up but don't quote me on that     make sure when you learn the tach signal you bring your RPMs up a little I usually set mine at like 1100
bigudi27
Posted: December 08, 2011 at 3:19 PM / IP Logged
Thanks chev104275, I download the information, I will do the learn tach to see what happens.
Bigudi
theppl
Member - Posts: 17
Posted: December 08, 2011 at 4:07 PM / IP Logged
The steps to learn the tach are:
Start the engine.
Within 5 seconds, hold down the button on the "command center".
In 3 seconds, it should turn the LED on and flash your lights once.
If over-rev is your problem, I would suggest that after you start the engine, bring the RPMs up slightly (with the gas pedal) to ensure it learns the increased engine speed.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
