audi a6 2010 avital 3001
splakatk14
Posted: December 09, 2011 at 5:28 PM / IP Logged
I'm having an issue with installing an Avital 3001 in my 2010 A6. I can't seem to get the system to learn then unlock wire. Has anyone done this install, and if so, what wire should I be connecting to in order to program the alarm correct. The wires I'm using are from a wiring diagram that I got from directed. The wires say that the connections should be driver lock and driver unlock motor wire. Any help would be greatly appreciated. Thanks in advance.
triniforever
Copper - Posts: 323
Posted: December 10, 2011 at 9:36 AM / IP Logged
The lock/unlock wire is the same and it's PURPLE / red found in the drivers door control module and it's a resistor based system meaning u have to measure the resistance for lock and unlock and use the correct resistors .
triniforever
splakatk14
Posted: December 10, 2011 at 2:52 PM / IP Logged
I'll try using power lock/unlock. Thanks for the info.
splakatk14
Posted: February 29, 2012 at 3:32 PM / IP Logged
So it's almost 3months later and I still am having issues with this Audi. If anyone has had experience with an avital 3001l Oem integration alarm, please let me know. I'm stuck with the programming portion of the alarm. It allows me to program arm, but not disarm. If I switch wires, then it programs disarm and not arm. Please help!!! Using the lock and unlock motor wires like dei says to use.
tedmond
Gold - Posts: 4,610
Posted: February 29, 2012 at 6:25 PM / IP Logged
that system uses varying resistance on the lock/unlock. Cut your losses and buy yourself an evo-can for 70bucks. It will do more than door locks. such as triggers, trunk, hood, tach etc.
Ted
Compustar Expert
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
