02 chevy silverado 2500hd diesel
slick00m
Posted: December 27, 2011 at 12:56 PM / IP Logged
I just got an autopage alarm/remote start and I'm trying to find what all i need to install it. I'm unsure if i need a data link box or not. And if i do will it control the lock/unlock or will it only disarm the factory alarm?
offroadzj
Gold - Posts: 2,043
Posted: December 27, 2011 at 1:04 PM / IP Logged
You can take your pick on the bypass. If you like the xpresskits then your best bet is the DB-ALL with the 401.GM5 v1.06.01 but you will have to get it from someone who can flash it for you with that firmware (unless you have the updater). It will do the locks, data immobilizer bypass (no key required except for programming), as well as hood and tach. I've had pretty good luck so far with the DB-ALL bypasses.
idatalink is another good source if you want to check them out as well. No matter which one you go with, use the wire to wire connections... don't trust the data to data.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
slick00m
Posted: December 27, 2011 at 1:29 PM / IP Logged
If I get the idatalink do I need to get a specific version on it?
Thanks for your help.
tedmond
Gold - Posts: 4,610
Posted: December 27, 2011 at 2:04 PM / IP Logged
you will need the firmware designed for the silverado. similar to the dball, as those are flash specific for each vehicle.
Ted
Compustar Expert
jonyb
Copper - Posts: 60
Posted: January 02, 2012 at 10:40 PM / IP Logged
You'll need an ADS-TB.  Go to idata's site, put the vehicle info in, and you'll see the firmware.
John Bauer
Pro Installz
Paducah, KY
