old skoda alarm system
moh_farouq
Posted: December 29, 2011 at 12:32 PM / IP Logged
hi, i have Skoda 120 Gls 1983 and need it Alarm System installation digram/ help, thanks
Posted: December 29, 2011 at 5:14 PM / IP Logged
There will be no info anywhere on that vehicle. Any alarm fitted will be aftermarket.
These vehicles had no power anything so all you need are the following.
12v+
Ignition
Starter
All at ignition feed.
Door triggers. At the dome light or any switch. Make sure they all work.
Tail/hatch/trunk. Again if no trunk light fitted you will need to install a pin switch.
Hood/bonnet again pin switch install.
Just test to see which is which. All you need for testing on this vehicle is a light fitting off a wreck and its leads, though a DMM is preferred.
I doubt if anyone west of Germany remembers them.
moh_farouq
Posted: December 29, 2011 at 10:58 PM / IP Logged
HI, thanks “howie ll” I ll try, I found info written on the main unit:
SYMPHONY AUTO
ALARM SYSTEM
SY-V300
And a small piece of paper on it with: V3001555
thanks
Posted: December 30, 2011 at 2:05 AM / IP Logged
Sorry, the name doesn't mean a thing to me and I've been installing alarms since the mid 1970s!
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
