chevy dodge radio marriage possible?
musicman1
Posted: December 29, 2011 at 7:52 PM / IP Logged
I have a '98 Chevy C1500 WT with the stock AM/FM factory radio. I purchased an AM/FM/CD unit from a 2005 Dodge Caravan for $.01 on Ebay. It seems to work fine. Any suggestions on the easiest way to mate my new radio with my old truck. I think I understand what is needed, but would certainly appreciate any expertise from any of you out there. THANKS!
offroadzj
Gold - Posts: 2,043
Posted: December 30, 2011 at 8:31 AM / IP Logged
as far as wiring goes, I believe that Best buy carries reverse harnesses (male factory harness) that you can get for the dodge radio, then get a normal harness for your chevy, get a wire diagram for both and match up the wires. As far as mounting goes, it will probably be some custom brackets.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
musicman1
Posted: December 30, 2011 at 9:02 AM / IP Logged
Thanks for the suggestions.  I will check out our local BB tomorrow.  My son-in-law was a corporate exec with CC at the end.  He started out in car audio and I was alway impressed with CC's car audio resources.  I still miss that expertise.  Happy New Year!
Platinum - Posts: 13,726
Posted: December 30, 2011 at 11:41 AM / IP Logged
You will need a Metra 71-6502 to plug into the dodge deck. Also a Metra 40cr20 for the antenna jack of the dodge deck. You will need a Metra 40GM10 antenna adapter for the truck, and also a Metra 70-1858 for the truck end of things.
At retail 60 dollars for those 4 pieces.
musicman1
Posted: January 03, 2012 at 9:20 PM / IP Logged
Thanks for the replies.  I was able to score a Dodge harness plug from a salvage yard, a Chevy adapter at Walmart and the antenna adapter.  The only wire in the Dodge harness that doesn't match up to the Chevy adapter is one labled a 12 volt PCI bus.  My guru at the Chrysler dealership says to ignore it.  I have matched all the wires.  Any thoughts or suggestions?  Thanks!
haemphyst
Platinum - Posts: 5,059
Posted: January 04, 2012 at 1:19 PM / IP Logged
If you plug it in, and it works, all you need now is the fabrication.
However... The dual aftermarket wiring (back-to-back) harness suggestion was a GREAT one, as you'll be sure to get all the wires connected to the deck correctly.
