dual power input
meldog312
Posted: January 06, 2012 at 11:01 AM / IP Logged
Looking to re-wire some warning lights on a truck. Looking for advice on how to wire a relay(s) with dual power inputs. For example strobe lights are off but when brake lights are applied we want the rear red strobes to flash as well. And when strobe lights are on we do not want to back feed the power to the strobe controller or over power the led's and kill them.. how would we go about wiring these?
flyryde
Posted: January 07, 2012 at 8:35 PM / IP Logged
Maybe just wire tap into the wire that feeds the brake lights and use it to trigger a 5 pin relay.  Not sure if the trigger wire would see voltage if you had a power source hooked up to a switch also feeding the strobes at the same connection as the power coming from the relay, so you could just use a diode on the wire from the relay to keep it from back feeding when you use the switch.
That made sense to me, lol, I could be way off though?
oldspark
Gold - Posts: 4,913
Posted: January 08, 2012 at 3:21 AM / IP Logged
When you say "strobe lights" on with brakes, do you mean to power the strobe controller and its LEDs?
If so, an SPDT switch could be used. IE - the strobe controller goes to 30.
87A goes to the strobe power (switch etc).
87 goes to +V else switched brake +V (if it handles the strobe current).
85 to GND.
86 to the +V switched brake signal.
Hence the strobe "normally" passes thru 30 & 87A.
When the brakes are on, the relay energises hence switching the strobe controller to +V.
Friday, March 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
